W212 Hankkiminen
Main data
VIN WDD2120891A213578
Baumuster 212089
Sales name E 350 CDI 4MATIC BlueEFFICIENCY
Order number 0 9 529 40824 (Destination: Finland)
Delivery date 17 03 2010
PAINT1 792U PALLADIUM SILVER METALLIC PAINT
Interior color 708A LEATHER COMBINATION - GRAY
Engine 642856 40 957220
Gearbox 722962 09 615745
General data for model code 212089
SA codes
Parameter Value
030 ELECTR. REGULATED DIESEL FUEL PUMP
050 AEJ 19/2
061 STEUERCODE FUER KRAFTSTOFFPUMPE
108 CONTROL CODE MARKETING
1P1 CONTROL CODE MARKETING
1U2 SNOW GRID
1U4 VEHICLE WAXING WITH ADDITIONAL SCOPE
204B OWNERS MANUAL AND SERVICE RECORD - FINNISH
213 SPEED-SENSITIVE POWER STEERING/VARIO STEERING
218 REAR-VIEW CAMERA
228 AUXILIARY HEATER
230 PARKING GUIDANCE
233 AUTONOMOUS INT. CRUISE CONT. PLUS (DISTRONIC PLUS)
234 BLIND SPOT ASSISTANT
236 DAY DRIVING LIGHT
23P DRIVING PACKAGE
249 INSIDE AND OUTSIDE MIRROR AUTOMATIC DIMMING
255B No code designation available
268B AIRBAGLABLE - FINNISH/ENGLISH
275 MEMORY PACKAGE (DRIVER SEAT, STRG. COL., MIRROR)
279 ELECTRONIC GEAR RANGE SELECTION
287 THROUGH-LOADING FEATURE
291 PELVIS AIRBAG (PELVISBAG)
294 KNEE AIRBAG
298 SIDEBAGS IN REAR WITH BELT FORCE LIMITER
305B HEAD UNIT LANGUAGE - BRITISH ENGLISH
335B INSTRUMENT CLUSTER/HU LANGUAGE - ENGLISH
409 MULTI-CONTOUR SEAT, FRONT LEFT AND RIGHT
427 AUTOMATIC TRANSMISSION 7-SPEED
428 STEER.WHEEL GEARSHIFT BUTTONS/SHIFT PADDLE PAINTED
474 DIESEL PARTICULATE FILTER
476 AUTOMATIC LANE RECOGNITION
477 TIRE PRESSURE LOSS WARNER
512 COMAND APS WITH DVD CHANGER
529L FINLAND
581 AUTOMATIC CLIMATE CONTROL
5XXL EUROPE
600 HEADLAMPS - CLEANING EQUIPMENT
608 AUTOMATIC HIGH BEAM SWITCH (IHC)
610 NIGHT VIEW ASSIST
619 CORNERING ILLUMINATION
622 HEADLAMP WITH ILS, RIGHT-HAND TRAFFIC
666 PRODUCT PROT.F.TRANSPORT VEH. W/O TIE-DOWN HOOKS
670 RESIDUAL ENGINE HEAT UTILIZATION (MRA)
677 AVANTGARDE/STANDARD SUSPENSION
700A LEATHER COMBINATION
736 TRIM PIECES - ASH TREE WOOD BLACK (2A70)
800 AEJ 09/1
875 HEATED SCREEN WASH SYSTEM
915 FUEL TANK WITH GREATER CAPACITY - VOLUME 2
928 EXHAUST GAS CLEANING WITH EURO 5 TECHNOLOGY
954 EQUIPMENT PACKAGE FOR AVANTGARDE VEHICLES
966 COC PAPER EURO 5 TECH. W/O REGIST. CERT. PART 2
A21 SHIFT BY WIRE
A31 SOFTWARE (INDIVIDUAL)
A36 TORQUE CONVERTER HOUSING AGA
A49 CONVERTER WITH 3 FRICTION DISKS
A52 R- VALVE BODY ASSEMBLY WITH VGS 3
B12 WHEEL REPLACEMENT TOOL
F212 MODEL SERIES 212
FW LIMOUSINE
G962 TRANSMISSION CODE VERSION 62
GA AUTOMATIC TRANSMISSION
HA REAR AXLE
J52 ADDITIONAL CODE FOR DAMPING MAT
K10 SOFTWARE CONTROL FOR STATIC CURVE ILLUMINATION
K11 ADAPTIVE STOP LIGHT FLASHING
K13 CONTROL CODE FOR SERVICE INTERVAL 25000 KM
L LEFT-HAND STEERING
M005 VEHICLES WITH 4-MATIC-/ALL WHEEL DRIVE
M019 SERVICE REPOSITIONED
M30 DISPLACEMENT 3.0 LITER
M642 V6 DIESEL ENGINE OM642
P35 LIGHT PACKAGE (FFO)
R01 SUMMER TIRES
R11 17" LIGHT ALLOY WHEEL 5 DBL-SPOKE DESIGN ALL-ROUND
U01 REAR BELT STATUS INDICATION
U18 AUTOMATIC CHILD SEAT RECOGNITATION (AKSE)
U60 PEDESTRIAN PROTECTION - ACTIVE ENGINE HOOD
U72 DVD PLAYER WITH REGIONAL CODE 2, EUROPE, JAPAN
V06 SPEED- + LOADINDEX 95W
VL FRONT AXLE HALF, LEFT
VR FRONT AXLE HALF, RIGHT
Additional information from Foreign Organizations
Parameter Value
27, 28 Vaihteisto uusittu (tehdaskunnostettu) Transmissin changed (reconditioned) vanha numero: 72296202679425 uusi numero: 72296209615745 Uusi varaosanumero: A212270890180
Suomiautoksi aika hyvin varusteltu.
On hienon oloinen auto. Paljonko ajettu?
Tuo värkki ois ~300tkm mennyt.
xin811
Viesti Kirjoittaja xin811 »
https://www.nettiauto.com/mercedes-benz/e/9943115 ?
Ei tuo ainakaan kallis ole. Mikähän vaihteistoon tullut, jakovaihteistoa ei saa erikseen että sinne tulee sitten uus loota jos siihen tulee vikaa. Laakerit saa vaihdettua, jotain lukenu niistä.
Noista jakolaatikoista olen parina iltana lueskellutkin. Ei juurikaan anna aihetta riemunkiljahduksiin.
Taitaa olla sama sutonen kaikissa tuon ikäluokan matikeissa.
h.hartikainen
Viesti Kirjoittaja h.hartikainen »
Jakovaihteiston laakerit halvat ja helppo vaihtaa eikä niitä päntiönään tarvi vaihdella. Kaikki muutkin hilut tuonne jakovaihteistoon tarvittaessa saa.
2011 tuli aika paljon muutoksia moottoripuolelle kun tuli tuo 195kw malli.
Etuvetarin laakeri on ikävähkö vaihtaa.
Dieselross
Viesti Kirjoittaja Dieselross »
Itseasiassa se korttipaikka on SD, eikä PCMCIA. Eli huomattavasti sirompi rako. :shock:
sonikki
Viesti Kirjoittaja sonikki »
No mutta se kyllä on PCMCIA kun puhutaan pre-face w212:sta ja NTG4:sta nii kuin tässä tapauksessa. Kuvan SD-kortillinen comand on NTG4.5 :)
S212 E350 CDi -10
R230 SL500 -03
W639 116 CDi -11
Dieselross
Jatketaas saivartelua, pre-fl eli salmiakkikeulalla on tehty myös NTG4.5 version Comandilla 2011 alkaen :)
740 GLE
Viesti Kirjoittaja 740 GLE »
Joo, onhan näitä toki myös pre-facelift koreissa. Tuo on viimeinen versio, joka ei osaa BlueTooth PAN-profiilia, eli siis vaatii nettiliittymää varten joko iänkaikkisen Dial-Up Networkin osaavan puhelimen tai modernimpaan puhelimeen DUN applikaation.
Seuraavassa on sitten PAN-profiili, ja toiminee nykypuhelintenkin kanssa suunnilleen "heittämällä"?
Iso vaalee E200 CDI (S212)
TRA
Viesti Kirjoittaja TRA »
Nyt tuli S212 hommattua tuon W210 kaveriksi. Ensivaikutelma on kyllä mahtava, hienon auton on Mercedes tehnyt ja hitusen on menty eteenpäin tuosta väyrysestä :D Tarvinee kiikutella seuraavaan huoltoon dealerille, jotenki ei tuohon Wetterin huoltoon uskalla luottaa. Mitä tuon w212:n B3 huolto pitää sisällään, kun ei vanhasa väykyssä tainut moista huolto-ohjelmaa olla? kilometrejä seuraava huoltoon auto ilmoittaa 10tkm, mutta päiviä on jäljellä enään 20. Meinattelin jos tuon 7g tronic plus öljyt ja suodattimen vaihdattaisi samalla. Mikä tuolle laatikolle on tehtaan ilmoittama huoltoväli?
Kiitos ja anteeksi ennakkoon :lol:
edit. juupas, hetken luettua tuosta huoltosisällöstä, niin sehän voi olla mitä vaan riippuen ajetuista kilometreistä.
Petri Rintala
Viesti Kirjoittaja Petri Rintala »
Moi
Jos jollain on tarve hankkia W212 täältä sellaisen saisi autoliike tarjosi 16000 euroa kyseisestä laitteesta joten kaikki yli menevät tarjoukset huomioidaan.
Tuossa muutama kuva :)
Nätti puhtaana :D
Penkki tietysti rikki :evil:
Kohtuu kilsoilla :roll:
Palovamma niiltä ajoilta kun vielä mamman kans tupruteltiin :nocando:
aja millä ajat ja mersulla loput :pope:
Petri Rintala
Moi
Niiai on myyty :( (rouvalla alahuuli väpätti rinta-joupin pihalla kun vietiin mut eiköhän sitä ala hymyilyttään kun pääsee torstaina hampurissa GLC:n rattiin)
:kuski:
Mutta mutta jäi ylimääreks kumimattosarja ja pari tutkan anturia vilaskaa tualt torin pualelt.
Pete
Dieselross
Terve, laitoin torin kautta viestiä noista matoista.
Catiska
Viesti Kirjoittaja Catiska »
Minkälainen kapine näistä 212 sarjalaisista kannattaisi hommata kun ajateltu budjetti on 20 - 35kEur. Ajoa tulee vuosittain n. 60k km josta pääosa maantiellä.
Eli luonnollisesti diesel ja farmarikori sopii minun käyttöön parhaiten.
Varustevaatumiksia ei paljon ole, vetokoukku, distronic ja comand, muistipenkit iso plussa kun minulla ja emännällä on aika reilusti kokoeroa. Ajokilsat saisi olla maks 220tkm niin ei olisi kilsat vielä ihan tolkuttomat jos pari kolme vuotta ajaisi sillä.
220/250d, onko niissä jotain huomioitavaa tuossa hintaluokassa? Entä 350d vaikkakin siinä on suurempi kulutus... Vaihteistoja on kait tuossa hintaluokassa tarjolla 7g ja 9g lootia? Onko suurta väliä kumpi, vai tarjoaako uudempi merkittävästi pienemmän kulutuksen maantiellä?
Mitkä vuosimallit on "suositeltavampia"? Tuliko jossain vaiheessa jotain oleellista muutosta autoissa joita tuossa hintaluokassa on?
xin811
60 tuhannen ajomäärällä puolentoista litran kulutusero on vuodessa noin 1200€. Onhan se jo jotain. Neloskoneet on kyllä pontevia vetämään nekin, äänimaailmassa on se ero sitten.
Dieselross
Kaikki kolme kovaa eli Comand, Distronic ja muistipenkit voi olla hankalaa löytää samojen kilpien välistä ainakin 220/250cdi koneiden yhteydessä. Kutoskoneisissa on sitten paremmat saumat, mutta harvassa silti Saksassakin (pikahaku mobilesta tuotti vain 25 kpl S212, alle 125tkm ja 2011-2015). Mulla on noista 2/3 omassa 220cdi W212:ssa.
Jos faceliftin hankit niin ota sellainen yksilö missä on multibeamledit. Panoramakatto ei liene ihan täysin murheeton, itse ottaisin ilman jos mahdollista valkata. Penkit olisi syytä olla oikeaa eikä keinoeläimen nahkaa.
Vetokoukku on sen verran helppo laittaa jälkikäteen, ettei kannata muuten hyvää yksilöä sen puutteesta torpata.
Catiska
Kiitos hyvistä neuvoista!
Juutana
Viesti Kirjoittaja Juutana »
Dieselross kirjoitti:Kaikki kolme kovaa eli Comand, Distronic ja muistipenkit voi olla hankalaa löytää samojen kilpien välistä ainakin 220/250cdi koneiden yhteydessä. Kutoskoneisissa on sitten paremmat saumat, mutta harvassa silti Saksassakin (pikahaku mobilesta tuotti vain 25 kpl S212, alle 125tkm ja 2011-2015). Mulla on noista 2/3 omassa 220cdi W212:ssa.
Mulle osui kouraan sellainen Junge Sterne 2014 E350 BlueTEC viime talvena jossa noi kaikki on (ja lisäksi mm. Airmatic, Pre-Safe, Panoraamakattoluukku, koukku, webasto, tuuletetut nahat, ja navi), eli löytyy kyllä. Oikeastaan ainoa minkä voisi puutteeksi laskea, on pelkkä takaveto, mutta itselleni se sopii paremmin kuin hyvin. Neliveto nostaa kulutusta, autoveroa ja käyttömaksua, enkä sitä kyllä oikeasti tarvitse. Saksan kaupassa jäi hinta vähän alle 30k€ ja siihen tuli sitten Suomen verot päälle. Aika tarkkaan aloittajan hintahaitarin yläpäässä, mutta on kyllä ollut perhanan mukavaa kyytiä.
Dieselross
Löytyy kyllä, mutta yleensä vaihtoehtoja ei ole kovin montaa myynnissä yhtä aikaa, eli (voi) edellyttää kärsivällisyyttä sopivan metsästyksessä mikäli varustekriteerit on kovin tiukat.
Silloin kun CLS:ää itselle etsin, niin niistä kaikista tuhansista saksan markkinoilla olevista W218 korisista kun valkkasi varustekombinaation 4matic, COMAND, Distronic, sähkö/muistipenkit ja AMG-line coupen korissa niin myynnissä oli kaikki 9 autoa joista suurin osa joko poskettoman hintaisia tai epäilyttävä historia. Junge Sternejä oli muistaakseni 3 joista yhden sitten ostin, eikä ole harmittanut jälkeenpäin. Väristä jouduin tinkimään kun alunperin periaate oli mikä tahansa muu paitsi harmaa. No hopeanharmaahan se tietenkin on. :roll: :lol:
Mites alkupään audio20:seen bluutuutin kautta musiikin striimaus kännykästä?
Puhelintoimitoja en tarvi mutta ne taitaa käynnistyä aina bluutuutin mukana?
Jostain muistelen lukeneeni että sen voisi saada toimimaan tuossa audio20:ssä engineerin valikosta tai softapäivityksellä.
Kinnunen
Viesti Kirjoittaja Kinnunen »
Mika.T kirjoitti:Mites alkupään audio20:seen bluutuutin kautta musiikin striimaus kännykästä?
Ei kuulemma onnistu ilman raudan vaihtoa. Tätä harmittelin auton oston jälkeen kun autosta bluetooth-tuki löytyy, mutta se koskeekin vain puhelinta :x. 2011 jälkipuoliskolla tulee musiikin bt-striimaus.
-MB E250 CGI -10
-BMW M3 -11
Naapurifoorumilla onnistuu ilman raudan vaihtoa, kuulemma.
Onnistuuko tuohon vaihtaa uudempi audio20 tuosta noin vain???
Siis siinä tilanteessa ettei tosiaan muuten onnistu. Mitään aux in johtohelevettejä en kyllä mielellään alkais kattelemaan...
Media interfacea ei tuossa ko. vehkeessä ole.
Mika.T kirjoitti:Onnistuuko tuohon vaihtaa uudempi audio20 tuosta noin vain???
Ei kai se AUX-liitäntäkään hirveä sotku ole eikä varsinkaan kallis jos hankkii sellaisen audio streamausta tukevan bluetooth palikan ja sujauttaa sen AUX-liittimeen. Virtaa sekin tarvitsee, yleensähän noissa on sytkäriliitin vierellä. Ei ihan siisti mutta kaikki hanskaluukussa sisällä.
No juu. Äänenlaatu noissa palikoissa on useinmiten mitä sattuu suttua,
Mutta kiinnostaisi lähinnä saada puhelimen ohjaus suoraan soittimesta/rattinapeista, se onnistuu bluutuutin kautta kunhan soitin tukee audio striimauksen.
Jäisi esim kappaleen vaihdossa puhelimen lukituksien räpläys jne pois...
204
Viesti Kirjoittaja 204 »
Olisi Myynnissä alkuperäinen 212 sedanin
AMG sisustus kaikki oviverhoilut istuimet ,joissa on sähkö ja ilmasäädöt,
Säätöyksiköt on ovessa ja ilma säädöt istuimen sivulla.
Takasivu ovissa on rullaverhot.
Autolla oli ajettu 75 tkm.
Istuimet on reiettyä nappa nahkaa ja kunto on erittäin hyvä.
tästä saisi hienon sisustuksen autoon.
kuvia saatavissa.
karsaka(ät) gmail.com
AMG teksti on etuistuinten selkänojissa
