V126 300SEL-->300SDL Projektia+Kuvia-->Myyty.
Elementit meni suoraan paikoilleen. Paitsi nuo keskiäänet. niiden reiístä piti jyrsiä parista kohtaa milli pari pois.
Tuossa kuvassa puukolla jyrsityt kolot näkyykin.
http://img.photobucket.com/albums/v625/ ... 000666.jpg
Eli elementin rungolle piti tehdä kaks tuomosta pientä koloa.
VIN WDB210017
Plant 50
Model E290DT
Chassis 2100171A164138
Engine 602982 00 004789
Transmission 717460 07 045175
Tyres
Primary PIRELLI
Order 0 6 529 10754
Lights HELLA
Cab 00000
Delivery date 21.05.96
Dealer Finland (529)
Interior leather black or graphite (201)
Paint
572 ruby red metallic (с 01.01.1995)
Options
249 automatically dipping inside rear view mirror (с 01.06.1990)
260 elimination of model designation on rear lid (с 01.05.1968)
292 sidebag in front left and right (с 01.01.1994)
345 rains sensor for windshield wipers (с 01.10.1993)
524 paintcoat preservation (с 01.01.1964)
543 sun visor with vanity mirror, illuminated, left and right (с 01.11.1978)
570 folding armrest front w202/210 stowage box front with armrest (с 01.04.1970)
front folding armrest w202 - housing at front with armrest
581 automatic climate control (с 01.01.1977)
593 heat-insulating glass, all-around, heated rear window pane (single-sheet safety glass), band filter
green heat-insulating glass all round, heated rear window, single pane safety glass - tinted strip (с 01.01.1972)
600 headlamp wiper/washer (с 01.08.1971)
611 courtesy lamps for front and rear doors, with W124 also for central doors/W202 front doors only (с 01.11.1978)
630 ECE warning triangle (с 01.08.1980)
659 light alloy wheels -5-holes (avantgarde design) (с 01.10.1994)
668
673 high-capacity battery (с 01.01.1964)
873 seat heater for left and right front seats (с 01.02.1984)
954 equipment package for avantgarde vehicles (с 01.06.1993)
rotating emergeny flasher, front (red light)
984 elimination of ownership certificate but with coc papers (с 01.06.1993)
982 additional parts for Finland vehicle version (с 01.04.1990)
Kytkimen luistelu on loppunut :shock:
Boxilla sais kivasti voimaa ku säätää suuremmalle. :D Kone vain sammuu vedätyksessä jos on sääjöt liian isolla. :D Onneksi tuo vauhtipyörä rajaa käytettävän tehon pohjaamisellaan. :shock: Ei kehtaa vasiten hajottaa. :D
Paljonkohan tuo vakio loota kestää vääntöä?
Ässäkään ei ole liikahtanut senttiäkään sen jlk kun väykky saapui pihaan. :D
Ässä herätetty henkiin reilun kuukauden unesta. Hienosti pelaa. :D
Taas seisoi ässä kuukauden päivät. :D
Kävin taas ulkoilutamassa noin 30km matkan. Ja hienosti viheltää. :D
Varaosista on etupuskuri maalattu valmiiksi vaihdettavaksi. Samaten ovet odottelee sisäpuolien maalausta. Sais vaihtaa paikoilleen.
Hitaasti etenee tämä projekti. :shock:
The end.
Ässä myyty.
rami v
Viesti Kirjoittaja rami v »
no voi hele... en kerenny rikastua ja ostaa sitä pois!! :nocando:
MB 230 CE vm.89
sel420
Mesen cuuleri
Viesti Kirjoittaja sel420 »
Jouduitko tekemään paljon muutoksia tuon cuulerin asentamisen suhteen,kun taitaa tuo 300:sen syyläri täyttää runkopalkkien välin samoin kuin omassani 420:sessä. Olen nimittäin laittamassa omaani 2.5TD 20valve konetta ja cuuleria suunnitellessa todennut että tiukkaa tekee.Taitaa nuo putket mennä runkopalkkien alapuolella!!vai??
Juu putket suunnittelin niin että menevät runkopalkkien alta.
Sen jäähdyttimen edessä menevän poikkituen leikkasin pois. Tarkotus oli laittaa se puskurin runkoon kiinni mutta empä kerennyt. :D
